"short circuit" is completele different to "over voltage" protection. it makes no sense to choose one OR the other.I need a fast and simple short-circuit(or Over-voltage) protection circuit.
Well, then tell us how you decide it to work.How can I protect my power supply from over-current?
Simple, cheap and reliable:I need the simplest and reliable circuit.
From the information you gave until now: it´s the same with the new circuit.But fuse will burn by a over-current and you should dissemble your box to repair it.
As long as power is switched OFF you can not detect whether it still is short circuit or not.until the short-circuit be removed
All in all there is no cheap, reliable, simple solution ... otherwise you could buy them.
