Note: This feature currently requires accessing the site using the built-in Safari browser.
Thank you for your answer.Think of a 1-bit SR, which is just a single ff. After 1 clock the input data appears on the output. You need one clock to get the data in, but no clocks to get the data out.
That pretty much depends on how you define “take out the data”. The data is AVAILABLE after one clock. You are assuming that you need to clock that data into something else. What if you just need the data as the input to a logic gate?Thank you for your answer.
But in order to take out the data from the register you do need another pulse of the clock.
thank you very much.
