sharing nwell of of device and guarding
deepak242003
Full Member level 5
Banglore
n-well shielding
hello all,
Is there any issue if we share nwell of PMOS wiht that of guardring ?..??
or is it better to maintaing minimum well spacing between them.??
all kind of view are welcome...
deepak
erikl
Super Moderator
Staff member
Germany
deepak242003 said:
Is there any issue if we share nwell of PMOS with that of guardring ?..?? or is it better to maintain minimum well spacing between them.??
Sharing an n-guardring with the nwell practically is (nearly) the same as putting nwell-taps with minimum spacing at the periphery of the nwell, which is a smart practice anyway and very much recommended for good shielding. If you want even better shielding, put a p-guardring around the nwell with (at least) minimum spacing.
An extra (minimum spacing) n-guardring around the nwell doesn't make sense, in contrary could be detrimental as to build another parasitic npn BJT with the nwell.
    deepak242003
