gavin23
Junior Member level 3
If you're familiar with SFPs you'll know that they have a few control signals – TX Fault, TX Disable, SFP_Present, I2C, & Rate Select. Is there a standard register (ie for all SFPs) that give the status of these signals?
What I'd like to do is drive a signal such as Rate Select high or low and then read back through the I2C interface whether the mode was set.
Any ideas?
Gavin
Any ideas?
Gavin
