hi...
go to add components-->search for 7 segment display--->chose the type u want(common cathode/anode)--->add it to the work-space....
thats the way to do it...hope it helps..
hai goto proteus window and choose pick from libraries option and type seven segment led then add it to ur work space...resister is must to connect to interfacing controller and led....
In case you're curious where the seven-segment displays are in the library, open the "pick devices" window by clicking p on the keyboard. Under category, go to Optoelectronics. Under subcategory, select 7 Segment Displays.
