setup time and hold time
rajakash
Member level 2
critical to estimate frequency setup hold time
which one is critical to estimate maximum frequency..............
setup time is more important deciding maximum frequency .when we decide frequency we r consider set up time
mux
thanks friends. .......... do u know in 2:1 mux if select line is 'x' then wat is output.
the clock period has be greater than the max critical path time in the circuit
you have to be more specific, are you asking what will happen in the simulation or "real" hardware?
Becides theis no X in real hardware...
hold time is 0 for modern FF => setup time is to watch
setup time is the limiting factor for max. freq. as for ur second ques. if i/p of mux is 'X' then o/p is also 'x' but if u use casex statement in verilog then this problem will not occur
We calculate max. freq by using set up time parameter only.
For hold time we chck only whether our circuit works correctly or not.
