tboy501
Newbie level 1
- Joined
- Jul 3, 2009
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- North America
- Activity points
- 1,303
verilog $setup
the program works fine in behaviorial mode but when i sythesize and try to simulate the the gates version i have a problem with my testbench code as it gives me the following error, and i dont get any output(everything is 0):
"/CMC/kits/artisan_rcim/tsmc18.v", 23815: Timing violation in prog_counter_testbench.prog_counter_inst.\latch_counter_reg[2]
$setuphold<hold>( negedge G &&& (SandR == 1):702, negedge D:702, 1, 1 );
ive tried to use initial clock /2 and increase the cycle time but it still gives me the same error, i really dont know what else try pls help.i wanted to totally eliminate the latch from my original program code but my supervisor says theres no problem with the program code but its the testbench that is faulty as im trying to read more than one register at the same time the clock iput changes, but idf that were so, then clock/2 should have skewed the clock time wrt to the rest of the circuit. im confused
(the initial program is a programmable timer that functions in this mode as a countdown timer)
//**********testbench*************************************
module prog_counter_testbench ();
reg reset, CE, write_CR, clk, load;
reg [7:0] data_in;
wire data_out;
reg [7:0] data;
parameter cycle = 40;
initial
begin
clk = 0;
forever #cycle clk = ~clk;
end
initial
begin
reset = 0;
CE = 1;
write_CR = 0;
load = 0;
data_in = 0;
#cycle
// setting for reset to 1
reset = 1;
repeat (2) #cycle;
reset = 0;
#cycle;
// to set CE to low to enable chip
CE = 0;
#cycle;
// load values into the counter
data = 8'hfa;
load_counter(data);
// write_CR values into control register
// to enable counter and to put counter in mode 0
// which is a one shot mode
data = 8'b00000100;
write_CR_CR(data);
#2000;
$stop;
end
task write_CR_CR;
input [7:0] data;
begin
write_CR = 1;
data_in = data;
repeat (2) #cycle;
write_CR = 0;
data_in = 0;
#cycle;
end
endtask
task load_counter;
input [7:0] data;
begin
load = 1;
data_in = data;
repeat (2) #cycle;
load = 0;
data_in = 0;
#cycle;
end
endtask
prog_counter prog_counter_inst (reset, CE, write_CR,
data_in, clk, load, data_out);
initial
begin
$display ("Executing in Mode 0");
$monitor ("clk %b reset %b CE %b load %b data_in %b write_CR %b data_out %b", clk, reset, CE, load, data_in, write_CR, data_out);
end
endmodule
reg [7:0] data_in;
wire data_out;
reg [7:0] data;
initial
begin
clk = 0;
end
initial
begin
reset = 0;
CE = 1;
write_CR = 0;
load = 0;
data_in = 0;
#cycle
reset = 1;
repeat (2) #cycle;
reset = 0;
#cycle;
CE = 0;
#cycle;
data = 8'hfa;
load_counter(data);
data = 8'b00000100;
write_CR_CR(data);
#2000;
$stop;
end
task write_CR_CR;
input [7:0] data;
begin
write_CR = 1;
data_in = data;
repeat (2) #cycle;
write_CR = 0;
data_in = 0;
#cycle;
end
endtask
task load_counter;
input [7:0] data;
begin
load = 1;
data_in = data;
repeat (2) #cycle;
load = 0;
data_in = 0;
#cycle;
end
endtask
initial
begin
end
endmodule
