Register Log in
Setting Ron or Rds of LDO
Adithya_Pai
Newbie level 6
I am modeling LDO in PSpice, here i have selected spec as ZXCL280 in dropout vs output current I have understood this as resistance of the MOSFET from dropout graph. That is minimum resistance required for the MOSFET, 2 OHMS (Page No 4). I will be using Ron=1/kp(Vgs-vt)
https://www.digchip.com/datasheets/parts/datasheet/539/ZXCL280-pdf.php
How will i get to know the right Vgs to select ron, Is this the right method or any other alternative way you can suggest?
dick_freebird
Advanced Member level 5
USA
You probably want a substantially lower Rout, else as you
approach the dropout voltage you will "wind up" the error
amplifier and have no authority (small signal) over the
output.
The Vgs you can impose, depends on the pass FET gate
drive and pass FET species. A PMOS LDO can impose the
supply difference to the gate (but again you need "room
to move", besides what you'd calculate as a bare ohmic
minimum). A NMOS LDO will have an AUX supply and/or
a charge pump and these are design degrees-of-freedom
to some extent.
If this LDo happens to have a functional schematic in the
datasheet it may offer you these sorts of clues. If not the
presence or absence of an AUX supply may tell you things,
but I have also seen LDOs which "keep it all in house" with
charge pumps inside that you don't see pinned out.
Adithya_Pai
Newbie level 6
What is better approach to set Ron for simple LDO loop?
KlausST
Super Moderator
Staff member
feel free to use the internet search on your own:
* "LDO basics"
* *How to design an LDO"
* "LDO design tutorial"
.. or similar.
Many useful hits, even videos.
Klaus
Toggle Sidebar
Design Fast
