set_driving_cell and set_input_transition usage
ajeshar
Newbie level 2
I want to specify set_input_transition and set_driving_cell in a design.
My doubt is, is there a way to specify the input transition at the input of the driving cell(which I specify using the set_input_transition command)
Also, in the presence of set_driving_cell how is the transition at the input port computed
Any feedback will be helpful.
Regards
Ajesh
Typically you would use the set_input_transition on a pin that you are unsure of the source. This is a great way to constrain maximum transition time at a top level pin
(i.e. at the pad). set_driving_cell works best when used in conjunction with -lib_cell option. This allows synthesis to accurately gauge the transition time by taking into account the capacitive load of you driving cell (this information comes from the liberty files .lib or .db).
You can use set_input_transition to define the slew rate of your driving cell, and then use the set_driving_cell -lib_cell option to constrain the path in question.
