set_disable_timing constraint using wildcards not working
TonyLS
Member level 3
Boston, MA
Hi all,
I'm trying to use wildcards to disable timing arcs between the functional address pins, ADDR*, of a memory and the test clock of the memory, TCLK.
Multiple address pins using a wildcard does not work: set_disable_timing memory_instance -from TCLK -to ADR*
Single address pin does work: set_disable_timing memory_instance -from TCLK -to ADR1
Any ideas on how I can constrain all ADR pins without writing a constraint for each bit?
Thanks for your help.
This is likely a tool restriction, not an SDC feature/lack of feature. Which tool are you using?
I'm using dc_compiler. I'm sure there is a way in TCL to obtain a list of pins of the memory cell, filter the applicable ones and apply them to the set_disable_timing command. I'm not that proficient in TCL programming, but have been researching. Was hoping someone has already tackled this problem.
