servo motor control problem
Nipuna56
how to control the rotation angle of servo motor?
sorry, what you mean from it
Do you know the meaning of the term "servo"?
It is a short form for "servo-loop". Are you familiar with the term "closed-loop"?
Here is what wikipedia says:
A servomechanism, sometimes shortened to servo, is an automatic device that uses error-sensing negative feedback to correct the performance of a mechanism.
The term correctly applies only to systems where the feedback or error-correction signals help control mechanical position, speed or other parameters. For example, an automotive power window control is not a servomechanism, as there is no automatic feedback that controls position—the operator does this by observation. By contrast the car's cruise control uses closed loop feedback, which classifies it as a servomechanism.
