Service Manual for AIWA NSX-990
aiwa service manuals
Hola LEON!!!
No sigas buscando!! Yo me volví loco para conseguir lo mismo del NSX-990. ( El problema que tengo es que no encienden un par de leds del display , justo los del medio : frec. AM /FM, etc.), y encima me mandé un corto sin querer tratando de medir y se me quemaron varios componentes. Asi que estoy de liga. Pero lo que te decía es que cansado de pedir el manual de service por varios foros, lo pedí a APAE en Munro ,Gran Buenos Aires. La dirección es : Guido Spano 4565 y el tel.
011- 4762 3773.
Que tengas suerte , y un abrazo desde Villa Carlos Paz.
Vicente Malvica
aiwa nsx 990
Hola LEON!!!
011- 4762 3773.
Vicente Malvica
aiwa nsx 990 manual
why not try h**p://www.tv-master.ru/index.htm
:oops:
aiwa nsx 990 forum
may this help????
aiwa nsx-990
may this help????
nsx 990
I need also NSX990 Service Manual (Schematic),but still not enough POINT.
Or anybody can tell me name or type IC201 (under front BIG DISPLAY ) in front PCB ???
I get this NSX990 without IC201...,somebody remove it..and dont
replace with new one...
Before and after thanks very much...
Best Regards
*FYI IC201 = 16 PIN , PIN1 of IC201 connect to PIN 1 IC104 (LC 65204A).
aiwa nsx990
no tengo suficientes puntos, alguien podria mandarme el Aiwa NSX-990.pdf a soygabo@msn.com
aiwa manual
Hi everybody, I would really appreciate if someone could help me with the subject manual. The cd player doesn't work anymore. very many thanks
Added after 41 minutes:
I've found this one .... can someone tell me if it's the same? Anyway....here it is
aiwa nsx manual
I've found this but I don't if it is the same .... anyway here it is
aiwa 990
I'm having trouble with the cd player. Is the posted manual the right manual ?
manual aiwa 990
Can anyone confirm if this is the right manual ?
nsx-990_254145249.pdf
Aiwa NSX 990 and Aiwa ZR 990 are not the same, their model and circuits are different.
Added after 30 minutes:
I need the Service Manual or Schematic of the AIWA NSX-990, if someone have it please send it to m_ehsangar at yahoo dot com
aiwa 990 -yoreparo
As download embedding?
