server with another 100 microcontroller
masud58
Full Member level 2
Dhaka, Bangladesh
Hi all
Please Help Me . I have Design A hardware and simulate it. It works very fine. if i want to comunicat each other from 100 feet , cabel need RX, TX, GND . It will be work or not? I can't like to use max 232,
Masud
http://geocities.com/matrixele/mypage
can i use buffer ? like 74hc04, 74hc07?
i dont like to use max 232 core.
thanks
masud
It will probably work with RS232 and if its for hobby go ahead. If its for work.. use RS485 or I2C. Maybe if they had chinese feet :p
I2C is short distance communication at PCB level.
For large distance use RS485, or CAN bus.
Is that schematic for real ??
All receivers are connected together , and all xmitters the same.....
How will a receiver ever receive anything with no xmitter connected ?
/Bingo
Hi!
RS-485 is the right solution to your problem.
You should call the server 'master' and the clients 'slaves'.
DATASHEET MAXIM RS-485 Transceiver
MAX485E up to 32 transceivers on the bus.
MAX487E and MAX1487E up to 128 transceivers on the bus.
Example with RS-485
I2C on long cables:
Using the Philips P82B715 I2C extender on long cables.
(Read first AN444.pdf).
P82B715 I²C bus extender:
P82B715 Datasheet:
P82B715 Application Note:
One mile long I2C communication using the P82B715:
Best regards,
Luciano
