DoraSzasz
Junior Member level 1
verilog serial to parallel
I want to make a serial to parallel converter for 11 bits with 7495 registers. I made the code for register and for counter,and this is the principal program that cause me problems....I have some errors at parameters declaration and maybe when I put the stimulus,at testing program....I sent you the main program,the counter and the shift register...(the counter and the shift register are correct-I check it)
Thank you a lot for helping me!
Here is the main program:
module Main(
input CLK,
input [10:0] PIN,
output OUT
wire Qa,Qb,Qc,Qd,q1,q2,q3,q4,w1,w2,w3,w4;
wire M,L;
reg a;
//first instance
counter inst1(.CLRM(1'b1),.LOADM(L), .ENT(1'b1), .ENP(1'b1), .CLK(clk),.A(1'b0), .B(1'b0), .C(1'b0), .D(1'b0), .Qa(q1), .Qb(q2), .Qc(q3), .Qd(q4), .RCO(a));
always @(q1,q2,q3,q4)
begin
if (Qa==1 & Qb==1 & Qc==1 & Qd==1) assign a=1'b1;
else assign a=1'b0;
end
//second instance for frequency divider
counter inst2(.CLRM(1'b1),.A(1'b0), .B(1'b0), .C(1'b0), .D(1'b0), .ENT(a), .ENP(a), .LOADM(L), .CLK(clk),
.Qa(w1), .Qb(w2), .Qc(w3), .Qd(w4),.RCO(1'b0));
assign M=!(q1|q2|q3|q4);
assign L=!(w3&w2&q4);
reg [10:0] BOUT;
//reg mode;
//always @(Q1,Q2)
//begin
//if( Q1==4'b0 & Q2==4'b0) assign mode=1'b1;
//end
shiftregister inst3(.mode(M), .clk1(clk), .clk2(clk), .ser(1'b0), .a(PIN[10]), .b(PIN[9]), .c(PIN[8]), .d(PIN[7]), .qA(BOUT[0]), .qB(BOUT[1]), .qC(BOUT[2]), .qD(BOUT[3]));
shiftregister inst4(.mode(M), .clk1(clk), .clk2(clk), .ser(BOUT[3]), .a(PIN[6]), .b(PIN[5]), .c(PIN[4]), .d(PIN[3]), .qA(BOUT[4]), .qB(BOUT[5]), .qC(BOUT[6]), .qD(BOUT[7]));
shiftregister inst5(.mode(M), .clk1(clk), .clk2(clk), .ser(BOUT[7]), .a(PIN[2]), .b(PIN[1]), .c(PIN[0]), .d(1'b0), .qA(BOUT[8]), .qB(BOUT[9]), .qC(BOUT[10]),.qD(OUT));
endmodule
Here is the counter:
module counter(
input CLRM,
input LOADM,
input ENT,
input ENP,
input CLK,
input A,
input B,
input C,
input D,
output Qa,
output Qb,
output Qc,
output Qd,
output RCO
reg [3:0] count;
always @(posedge CLK)
if(!CLRM) count<=4'b0;
else if(!LOADM) count <={A,B,C,D};
else count <=count + (ENP&ENT);
assign Qa=count[3];
assign Qb=count[2];
assign Qc=count[1];
assign Qd=count[0];
assign RCO=(ENT)?(count==4'd15):0;
endmodule
Here is the shift register:
module shiftregister(
input mode,
input clk1,
input clk2,
input ser,
input a,
input b,
input c,
input d,
output reg qA,
output reg qB,
output reg qC,
output reg qD
wire internalclk=(mode)? clk2:clk1;
always @(negedge internalclk)
begin
qA<=(mode)? a:ser;
qB<=(mode)? b:qA;
qC<=(mode)? c:qB;
qD<=(mode)? d:qC;
end
endmodule
module Main(
input CLK,
input [10:0] PIN,
output OUT
wire M,L;
reg a;
//first instance
begin
else assign a=1'b0;
end
reg [10:0] BOUT;
//reg mode;
//always @(Q1,Q2)
//begin
//end
endmodule
module counter(
input CLRM,
input LOADM,
input ENT,
input ENP,
input CLK,
input A,
input B,
input C,
input D,
output Qa,
output Qb,
output Qc,
output Qd,
output RCO
reg [3:0] count;
assign Qa=count[3];
assign Qb=count[2];
assign Qc=count[1];
assign Qd=count[0];
endmodule
input mode,
input clk1,
input clk2,
input ser,
input a,
input b,
input c,
input d,
output reg qA,
output reg qB,
output reg qC,
output reg qD
begin
qA<=(mode)? a:ser;
qB<=(mode)? b:qA;
qC<=(mode)? c:qB;
qD<=(mode)? d:qC;
end
endmodule
