serial programming on proteus - max232 problem
wolverine123
Newbie level 6
max232 problem
hey guys i was trying to simulate serial programming on proteus and tried to send a character, i added a virtual terminal at the beginning before passing through max232 and i could see the character fine... but after passing through the max232 i never got the same character again... like if sent 'A' i would get '_' after passing through max232.... can anyone please help :S
Re: max232 problem
No one can answer your question without your circuit
Check your circuit twice. Only possible problem is with the circuit
Nandhu
max232 problem
Remember that the Max effectively inverts your signal. You need to send it through another Max
Re: max232 problem
The following pic shows the text being transmitted fine
but the following after passing through max232 shows something else
But if it's getting inverted then i wont see the desired output when i attach a serial cable and test the output in hyperterminal????
max232 problem
the vterm in ISIS has to be inverted to connect a mx232 in simulation... have you selected to invert RXD and TXD in the vterm properties??? maybe that's the problem...
Re: max232 problem
I know this very old thread, but I want to put the answer there just incase anyone look for it.
Right click on the virtual terminal, edit properties, change from normal to inverts.
