serial printer protocol
madjid
Member level 1
Member level 1
Does anyone know the graphic protocol that the Yokogawa uses when it sends a graphic screen to the printer? I want to have the output sent to a PC (rather than a printer) and then generate the picture as a bitmap.
I know some of the Yokogawa printer codes and make a Converter that convert the codes for HP Inkjet printer. You can visit my Web-blog at
http://www.printerconverter.blogspot.com/ (I just created the web site a few days ago. I am in adding more data to the web site.)
Which system you want the code? (Micro-XL, Centum-XL, or Centum CS)
Will It be easier for you to write the program on PC to capture the known code such as HP PCL or EPSON ESCAPE code?
LaTeX Commands Quick-Menu:
