serial port problems - two PCS are or communicating
infineonintern
setcommtimeouts
To people who handled with serial port programming, please help. I am trying to let two PCS
to generate communication between each other. I am new to serial port programming and have
written two simple programs to run on each PC. The program is a DOS application in windows
and is written in C++. One of PC will be the "reading" PC and the other PC will be the
"writing" PC. The "reading" PC will just read and display how many bytes that is sent from
the serial port of the "writing" PC. The problem now is, when i run the two programs on each
PC, the "reading" PC is reading from its own serial port and the "writing" PC is writing to
its own serial port. They are not handshaking or communicating. I have connected the two
serial ports via a NULL modem cable but it is not working. I wonder is there is anything
wrong with my code or the setting of the handshaking. Please guide!
This is the code for the "reading" PC (the output of the program just printf 0 bytes, how to
let it detect the 9 bytes from the "writing" PC?):
#include "windows.h"
#include <stdio.h>
#include <io.h>
#include <conio.h>
#include <stdlib.h>
#define maxBytes 32
#define MAX 128
int main()
	HANDLE hSerial;
	DCB dcbSerialParams = {0};
	COMMTIMEOUTS timeouts = {0};
	DWORD dwBytesRead = 0;
	char szBuff[maxBytes] = {0};
	int readbytes, i;
	//opening the serial port
	hSerial = CreateFile("COM1", GENERIC_READ | GENERIC_WRITE, 0, 0, OPEN_EXISTING,
FILE_ATTRIBUTE_NORMAL, 0);
	if(hSerial==INVALID_HANDLE_VALUE)
		if(GetLastError()==ERROR_FILE_NOT_FOUND)
			printf("Serial port does not exist\n");
		printf("Other errors\n");
	//setting parameters
	dcbSerialParams.DCBlength = sizeof (dcbSerialParams);
	//GetCommState is to retrieves the current control settings for a specific
communications device.
	if (!GetCommState(hSerial, &dcbSerialParams))
		printf("Not GetCommState, not able to retrieves the current control.\n");
	dcbSerialParams.BaudRate = CBR_9600;
	dcbSerialParams.ByteSize = 8;
	dcbSerialParams.StopBits = ONESTOPBIT;
	dcbSerialParams.Parity = NOPARITY;
	//SetCommState configures a communications device according to the specifications
	//in DCB. The function reinitializes all hardware control settings but it does not
	//empty output or input queues
	if (!SetCommState(hSerial, &dcbSerialParams))
		printf("Not SetCommState, cannot configures serial port according to DCB
specifications set\n");
	//setting timeouts
	timeouts.ReadIntervalTimeout = 50;
	timeouts.ReadTotalTimeoutConstant = 50;
	timeouts.ReadTotalTimeoutMultiplier = 50;
	timeouts.WriteTotalTimeoutConstant = 50;
	timeouts.WriteTotalTimeoutMultiplier = 50;
	//SetCommTimeouts set the time out parameters for all read and write operation
	if (!SetCommTimeouts(hSerial, &timeouts))
		printf("Not SetCommTimeouts, cannot set the timeout parameters to serial
port\n");
	if(!ReadFile(hSerial, szBuff, maxBytes, &dwBytesRead, NULL)){
		 printf("error\n");
	else{
		while (ReadFile(hSerial, szBuff, maxBytes, &dwBytesRead, NULL))
			readbytes = sscanf("%d", szBuff);
		for (i = 0; i < readbytes; i++)
			printf("%c",szBuff[i]);
		printf("\n");
		printf("Read %d bytes from serial port.\n",readbytes);
	//closing down
	CloseHandle(hSerial);
This is the code for "writing" PC:
#include <stdio.h>
#include <io.h>
#include <conio.h>
#define maxBytes 32
int main()
	HANDLE hSerial;
	DWORD dwBytesWrite = 0;
	char szBuff[maxBytes]= {0};
	int i;
			printf("Serial port does not exist");
		printf("Other errors");
		printf("Not GetCommState, not able to retrieves the current control.");
specifications set");
	//setting timeouts
	//SetCommTimeouts set the time out parameters for all reand and write operation
port");
	//Writting data
	//WriteFile write data from the specified file or i/o devices.
	if (!WriteFile(hSerial, szBuff, maxBytes, &dwBytesWrite, NULL))
		printf("Serial port cannot write file");
	else
	while(1)
			i = sprintf(szBuff, "testing .\n");
			printf("Writing %d bytes to serial port.\n", i);
	//closing down
Please help anyone!
arthur0
Full Member level 2
Stockholm, Sweden
Re: serial port problems
Well, this definitely not how I would do I/O on the serial port, but since I don’t intend to give a course in programming, I will just name that a proper approach is to open the file with the FILE_FLAG_OVERLAPPED set, provide a properly initialized OVERLAPPED structure and use different threads for reading and writing with some synchronization in place.
Now in your example, I can’t help noticing that you call WriteFile with a pointer to a buffer that you only fill later on. Not only is this not a nice thing to do, but it won’t work because in non-overlapped mode WriteFile won’t return until it’s done writing ‘maxBytes’ bytes of garbage, so subsequent alterations to the buffer are meaningless.
At the other end of the pipe, you call ReadFile once in what it seems as an attempt to test for errors? In reality this call will not return until it either reads ‘maxBytes’ bytes, or receives an EOF. In any case you discard the read data when you do subsequent call in the ‘else’ path (assuming the call succeeds).
To summarize:
- on the read-side, remove the ‘if/else’ and keep only the ‘while’;
- on the write-side, initlialize the buffer before the ‘while’; remove the ‘if/else’, but keep the WriteFile (in a ‘while’, if you want).
Even if this works, I’d suggest you look into doing it asynchronously, as it should be done.
Arthur
