Serial Port - Matlab - Problem
ashwini1
Bangalore
serial problem matlab
In my application i am reading data from serial port. I have created exe of the application using matlab compiler(mcc) . THe problem is that whenever i get null or whenever there is time out, program stops running and there will not be any error message displayed on the command prompt.
Note: i am reading serial data at every one second. I have used timer to poll the serial port at every one second.
One more observation is that the same code works fine when i run it in matlab. I mean even if null is received/'time out' occurs, program polls serial port in next iteration (next cycle of timerfcn).
Any ideas !!
Thanks !
Ashwini
I am Ahmad. I am beginner in Matlab and i have seen that you are also working the same what i like to do. Actually, i have 8 sensors and i am sending data through the serial port. my data is unsigned characters. what i should do to convert these data into normal measurement from the sensors using matlab knowing that i have constructed the serial port in matlab...do i used the fread instructions or something else....the data sequence is the following 55 55 55 55 then 16 byte from each sensor then 55 55 55 55
Could you help in that ?
