irfanhab
Member level 1
I'm designing cicuit which makes use of the serial port,.
Now the 89c52 microcontroller has an inbuilt UART, I read from somewhere, that it needs +10V for a logic 1 or soemthing, but I'm powering the MCU with +5V, will it work? and from where do I apply extra +12V??
One more questions is that if I build a device to control another device both running on the MCU UART, do i need to supply extra power to both?? that is power apart from the +5V to the MCU?
Someone was telling me about a MAx 232 chip which converts the Rs-232 (serial port) voltage levels to ttl voltage levels, but I think the max 232 chip is only when I'm using the computer's serial port, or do I need to use it also in MCU to MCU communication?
