serial port- 1Hz frequency from pin's of com port
muhammedan
serial port
hello everybody.I want catch directly 1Hz frequency from pin's of com port (in other word if i connect one led directly to the serial port it regularly on and off).Is it operative and how?
serial port
It can be done very easily. What language are you using ??
Re: serial port
Man ....
U r using which type of serial comm RS232 .... then to check that ur serial port is working or not just short pin nos 2 & 3 with any metal body and open Hyperterm of the PC and check that whatever you are writing is getting back to u or not .....
if it is then the comm lines are healthy ....else it is faulty .....[:)]
Re: serial port
I am using c++ language.
serial port
This is good you see that link:
i have made this type of interface with microcontroller
AT89c52 connected with LEDs.
Re: serial port
Hi There!,
I think in your case u need to use the RTS pin.
The EscapeCommFunction API enables u to do so.
u can find it here:
http://msdn.microsoft.com/en-us/library/aa363254(VS.85).aspx
just use the RTS setting function and and sleep function.
I hope that helped.:D
