Serial External EEPROM
bangunprayogi
Newbie level 5
Bandung, Indonesia
external eeprom
In EEPROM 24C64/24LC64 to PIC16F84A interfacing with I2C wire communication, should the A0,A1 and A2 are grounded?Then, how to refresh that serial external EEPROM?
Read the datasheet.
If you only have one device then make them logic zero.
What do you mean by refresh? It does not need a refresh cycle like a dynamic RAM.
EEProm doesn't need to be "refreshed" , and the three address line allow you to connect up to 8 similar devices to the same I2C interface ..
Regards,
IanP
when your system has many 24C64 chips, A0, A1, A2 are used to
setup each chip's i2c address.
best regards
eeprom is very easy to use.
the operation of read/write a eeprom is just like to operate a static ram.
