Serial Data with a pic...... help!
chevymn1964
Full Member level 2
Santa Rosa, Ca.
Hello,
Im working on a project and I am now stuck....... I am using a pariallel in/ serial out shift register going to a PIC ( 16F84 ) then to a serial in/ pariallel out shift register..... What I need to do is read the 8 inputs and output the corrosponding output with a 1sec pulse each time the input goes high or low.... I know I can use a pic with more i/o's but I am going to add up to 16 i/o's as soon as I get the 8 i/o working.... I got as far as taking the data through the pic and outputing it but I cant seem to figure out how to pulse the output....... any help would be great! thanks!!!!
chevymn1964 said:
....What I need to do is read the 8 inputs and output the corrosponding output with a 1sec pulse each time the input goes high or low....
On power up, read the inputs and store in a register. Read the inputs again and compare with the stored value. If there is a change... say in a perticular bit, save the current read bit pattern and make the output high and after 1 second make it low.
Cheers
Ravi
