bouvett
Newbie level 2
Hi guys,
I have already read many of the links available on this forum and on the web in general, but unfortunately i still haven't solved the problem in my code - I'm sure a geek out there will solve this in minutes but i'm still a newbie unfortunately :sad: .
i am trying to read data from a serial port, process the data and then transferring it back serially. Now the read is surely right, but unfortunately when i go to write a problem arises. I am in actual fact calibrating a touch screen to a glcd.. now the transmission of data between the embedded board i am using and the matlab is wrong when i write back to the serial port but good when i just read.
The code is:
i suspect that the problem is that i am all the time changing the timeout period. The reason for doing this is because i want to read the port continously but if i keep the same time out period for writing an error is returned.
Thanks for your time guys.
regards,
bouvett
---------- Post added at 21:20 ---------- Previous post was at 21:09 ----------
if i just write to the serial port without changing the timeout i get an error:
??? Error using ==> serial.fwrite at 199
A timeout or Ctrl-C occurred during the write operation.
Error in ==> touch_screen_calibration at 102
fwrite(SPort,x_cal);
I hope this helps as a clue.
thanks guys
---------- Post added at 21:30 ---------- Previous post was at 21:20 ----------
I have confirmed that the problem is whit how i am handling the timeout period. when i set the time out period to 0.01, i would not need to change it before writing to the serial port but unfortunately this is quite slow for my application.. so what i really need is a proper handling of the changing of the timeout period.
thanks again
---------- Post added at 22:37 ---------- Previous post was at 21:30 ----------
The error is very strange since it can read very fast but it cannot write that fast not even 5 times slower... this is constantly giving me a timeout error when trying to write to the serial port
The code is:
function touch_screen_calibration ()
%This function will calibrate the touch screen for the natural input
%calculator. What it does is to accept input serially from the glcd which
%will be of the form x,y and then provide a calibrated output x_cal,y_cal
%again serially to the fpga.
%calibration constants
x_d0 =12;
x_d1 =114;
x_d2 =63;
y_d0 =6;
y_d1 =30;
y_d2 =57;
% Opens a serial communication object
SPort=serial('COM7','BaudRate', 9600,'Parity', 'none','DataBits',8,'StopBits', 1);
set(SPort,'InputBufferSize',20480000);
set(SPort,'Timeout',0.00000001);
fopen(SPort)
coordinates = zeros(1,5000);
counter =1;
% asynchronous mode
SPort.ReadAsyncMode = 'continuous';
readasync(SPort);
%Setup calibration variables
cal_counter = 6; %used to keep track of which calibration point has been received
%and whether calibration is ready.
A=0.0;
B=0.0;
C=0.0;
D=0.0;
E=0.0;
F=0.0;
K=0;
while(1)
IN_DATA=fread(SPort,1,'uchar');
if(IN_DATA ~= -1)
IN_DATA
switch (cal_counter)
case 0
x_0 = IN_DATA;
cal_counter = cal_counter +1;
case 1
y_0 = IN_DATA;
case 2
x_1 = IN_DATA;
case 3
y_1 = IN_DATA;
case 4
x_2 = IN_DATA;
case 5
y_2 = IN_DATA;
K = (x_0 -x_2)*(y_1 - y_2) - (x_1 - x_2)*(y_0 - y_2);
A = ((x_d0 - x_d2)*(y_1 - y_2) -(x_d1 - x_d2)*(y_0 - y_2))/K;
B = ((x_0 - x_2)*(x_d1 - x_d2) -(x_d0 - x_d2)*(x_1 - x_2))/K;
C = (y_0*(x_2*x_d1 - x_1*x_d2) + y_1*(x_0*x_d2 - x_2*x_d0) + y_2*(x_1*x_d0 - x_0*x_d1))/K;
D = ((y_d0 - y_d2)*(y_1 - y_2) -(y_d1 - y_d2)*(y_0 - y_2))/K;
E = ((x_0 - x_2)*(y_d1 - y_d2) -(y_d0 - y_d2)*(x_1 - x_2))/K;
F = (y_0*(x_2*y_d1 - x_1*y_d2) + y_1*(x_0*y_d2 - x_2*y_d0) + y_2*(x_1*y_d0 - x_0*y_d1))/K;
case 6 %calibration ready therefore start reading X and Y co-cordinates
X = IN_DATA;
case 7
Y = IN_DATA;
if( (X<128 && X>=0) && (Y<64 && Y>=0))
%Process data and send it serially
%x_cal = A*X + B*Y + C;
%y_cal = D*X + E*Y + F;
x_cal = X;
y_cal = Y;
coordinates(1,counter) = X;
coordinates(1,counter+1) = Y;
counter = counter +2;
%slow down transmission for send
stopasync(SPort);
set(SPort,'Timeout',1);
%readasync(SPort);
x_cal = round(x_cal);
y_cal = round(y_cal);
fwrite(SPort,y_cal);
stopasync(SPort);
%readasync(SPort);
cal_counter = cal_counter -1;
save coordinates coordinates
end
otherwise cal_counter = cal_counter; %dummy
end
end
end
end
regards,
bouvett
thanks guys
thanks again
