Register Log in
serial communication using matlab
soinarose
Junior Member level 3
india
sir,
i want to display a wave from function generator in matlab. i convert analog signal using adc. The microcontroller which im using is PIC 16F877A. my plan is to transmit it through serial port.. hw can i receive data through serial port...
Pls help me..
Sonia.
bassa
Super Moderator
Staff member
Sri Lanka
soinarose said:
sir,
Pls help me..
Sonia.
Matlab examples available in the "Math Works web" you may browse their web for more information.
Create serial port object in matlab
What Is the MATLAB Serial Port Interface
Guide to Serial Port Interfacing
hope this helps
regards
bassa
    soinarose
    V
soinarose
india
Thank u for ur valuable information.. im getting values from PIC... but after some time its automatically closed... im getting an warning ..
Warning: The input buffer was filled before the Terminator was reached.
pls help me sir to solve this error....
Regards
Sonia..[/b]
bassa
Super Moderator
Staff member
Sri Lanka
Regards
Sonia..[/b]
I think before you read the data from matlab, try to read it using hyper terminal, if this test is fine then check your matlab code
check math works web for this error. here some links
Problem reading lines from a serial device
Also check chapter 5 "Controlling Serial Port Instruments" of Instrument Control Toolbox here attached
good luck!
regards
bassa
soinarose
india
sir, im getting datas in hyper terminal...
cavelli
Newbie level 1
spain
Hi, i want to use the serial port with matlab for i can read the sensors data. i'm using the next comand:
port=serial ('COM1', 'BaudRate',9600,'DataBits',8,'StopBits',1);
fprintf(port,'%c','%1');
[tline,count,msg}=fgetl(port);
fclose(port);
delete(port);
clear(port);
But "tline" parameter only show me one character and "count" only count one.
Why?
Thanks.
rongo024
Bangladesh
You need not go through any microcontroller.
Matlab can interface audio in .So just put your analog signal at your audio in and read the value at this port.
