Register Log in
Serial Communication problem?
Zerox100
Full Member level 6
Is there an easy way to pass 16kbit realtime stream over a 19.2kbps noisy serial link (without clock)? I want a simple format (not very complex as HDLC). It must be cover very easy data with minimum fade packet?
THX,
vinci.
Junior Member level 1
south P
i think HDLC is the simpliest protocol recogniseable by two devices. You can always use shorter sequence of signs: 1 bit start; 7 bits ASCII; 1 bit parity; 1 bit stop, but this is the question if devices recognise that frame between each other.
PaulHolland
Advanced Member level 2
Holland
Hi, Don't that it is possible. Your do not have enough bandwidth. If you want to try something base the design on CIRC4 (see CD standard)
regards,
Paul.
Toggle Sidebar
