serial communication in java
visva
Member level 3
i have tried serial communication in java. But it is not working. i don't know what is going on. its reading ports and checking ports and doing everything. but the serialEvent is not working when i send data from micro_controller.
note: i checked in hyper terminal the data is receiving. but i don't know what problem in the following program. please any one help me to solve this problem.
or otherwise show me any example program and explain. i need it fast to submit my project.
import java.io.*;
import java.util.*;
import javax.comm.*;
public class SimpleRead implements Runnable, SerialPortEventListener
static CommPortIdentifier portId;
static Enumeration portList;
InputStream inputStream;
SerialPort serialPort;
Thread readThread;
public static void main(String[] args)
portList = CommPortIdentifier.getPortIdentifiers();
//Boolean i=portList.hasMoreElements();
while (portList.hasMoreElements())
//System.out.println("check");
portId = (CommPortIdentifier) portList.nextElement();
if (portId.getPortType() == CommPortIdentifier.PORT_SERIAL)
if (portId.getName().equals("COM13"))
System.out.println("port detection");
SimpleRead reader = new SimpleRead();
public SimpleRead()
try
serialPort = (SerialPort) portId.open("SimpleReadApp", 2000);
catch (PortInUseException e)
{System.out.println(e);}
try
inputStream = serialPort.getInputStream();
catch (IOException e) {System.out.println(e);}
try
serialPort.addEventListener(this);
catch (TooManyListenersException e) {System.out.println(e);}
serialPort.notifyOnDataAvailable(true);
try
serialPort.setSerialPortParams(9600,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
catch (UnsupportedCommOperationException e) {System.out.println(e);}
readThread = new Thread(this);
System.out.println("welcome");
readThread.start();
public void run()
try
Thread.sleep(20000);
catch (InterruptedException e) {System.out.println(e);}
public void serialEvent(SerialPortEvent event)
System.out.println("serial event");
switch(event.getEventType())
case SerialPortEvent.BI:
case SerialPortEvent.OE:
case SerialPortEvent.FE:
case SerialPortEvent.PE:
case SerialPortEvent.CD:
case SerialPortEvent.CTS:
case SerialPortEvent.DSR:
case SerialPortEvent.RI:
case SerialPortEvent.OUTPUT_BUFFER_EMPTY:
break;
case SerialPortEvent.DATA_AVAILABLE:
byte[] readBuffer = new byte[20];
try
while (inputStream.available() > 0)
int numBytes = inputStream.read(readBuffer);
System.out.print(new String(readBuffer));
break;
default:
System.out.println("There is no data");
break;
yes everything is ok.the following status(in picture) will show when i run this program finaly the cursor waiting for something. In here the port is detected. in that program there is no warning. the only problem is when i send data through serial port, the serialEvent is not working. Capture.PNG
send me if there is any serial port reading program in java
and explain me the procedure for run this serial communication program.
