Sensor for tracking distance with lower than 1mm accuracy??
Newbie level 6
Hi everyon,
I need to track a small object from a fixed position with 1mm accuracy, just need to know how far it is. What kind of solution do I need?
Thanks in advance
tinto
Junior Member level 2
Kerala, India
You can use an ultrasonic sensor to calculate the distance from nearly 2cm to 4m. Less than 1mm accuracy is possible with it. For example, a Ping sensor.
klystron
South Africa
Ultrasonic ranging has a temperature dependency that must be compensated for
