Sensor for Paper Thickness Measurement
Revathysrini
Junior Member level 1
Chennai
Hi all,
Which type of sensor is more accurate for Paper thickness Measurement (75-85 micron).
Thanks,
if there is a fixed dielectric constant then i´d use a capacitive sensor.
a mechanical solution can be to push the paper between two ball bearings and measure the distance..
optical: light shine through
it depends on some parameters wich solution to choose.
Klaus
