BALKRISHNA TULSYAN
Junior Member level 3
AT //ATTENTION COMMAND
ok
AT+CGREG? //NETWORK REGISTRATION STATUS
AT+CGREG=1
STETUS SHOULD BE 1,1
Parameter
<n> 0 disable network registration unsolicited result code
1 enable network registration unsolicited result code +CGREG:<stat>
2 enable network registration and location information unsolicited result code +CGREG: <stat>[,<lac>,<ci>]
<stat>
0 not registered, ME is not currently searching a new operator to register to
1 registered
AT+CGATT? //ATTACH/DETACH FROM GPRS SERVICE
AT+CGATT=1 //ATTACH GPRS SERVICES
<state> indicates the state of GPRS attachment
0 – detached
1 – attached
Other values are reserved and will result in an ERROR response to the execution command.
AT+CSTT="airtelgprs.com","","" //START TASK AND SET APN, USER NAME, PASSWORD
AT+CIICR //BRING UP WIRELESS CONNECTION WITH GPRS OR CSD
AT+CIFSR //GET LOCAL IP ADDRESS
AT+CIPSTART="TCP","[URL="http://www.google.com"]www.google.com[/URL]","80" //GMAIL SERVER IP ADDR AND PORT NO.
OK
CONNECT OK
after i got CONNECT OK msg from my SIM 900 MODEM , i got some output at the hyper terminal..that output i have saved as .htm file and when i tried to open it , i got output as displayed below
+CMT: "Airtel","","13/09/06,11:45:15+22" /-¶‘€’EDFEA1FB6C37B36F3266B2F97B760C1AC4FAAD01jÅFÆQ‡id_1264054062149_3‡Airtel MMSÆR‡/id_1264054062149_5‡ +CMT: "Airtel","","13/09/06,11:45:15+22" 100.1.201.172‡!…‡"id_1263902933063_4ÆS‡#8799‡$ÐÆU‡id_1263902933063_4‡«‡Airtel MMSairtelmm +CMT: "Airtel","","13/09/06,11:45:15+22" s.com‡ ‰ÆV‡Airtel MMSÆU‡6w4‡Airtel MMS‡9id_1264054062149_3‡4[I]**broken link removed**[/I] +CMT: "Airtel","","13/09/06,11:45:16+22" !@ieeH)al?Y?(?9tJ1Y?I:ed9+FAH9ehQKfmow as default on your phone! Access Internet by Long Pressing '0' key on Nokia or by launching the WAP/WEB browser on oth +CMT: "Airtel","","13/09/06,11:45:16+22" !@ieeH2r!!CvMA2sO@_?nA;sR9;ud?4ada+6n apply at 10p/10KB for 2G services and 3p/10KB for 3G services
what does this mean???
what should i do next if i want to send some mail to a particular person using SMTP protocol..??
ALL THE EXPERTS ....please help..
waiting for reply..
