#include<string.h>
#include<reg51.h>
unsigned char x=0,i,g[20];
unsigned char s1[9]="AT\r\n"; //send "AT" command modem will response
unsigned char s2[18]="AT+CIPMODE=0\r\n";//Select TCPIP Application mode
unsigned char s3[30]="AT+CLPORT=\"UDP\",\"3500\"\r\n"; //set Local Port
unsigned char s4[45]="AT+CIPCSGP=1,\"airtelgprs.com\"\r\n";//set csd or GPRS for Connection mode "ur GPRS provide address"
unsigned char s5[15]="AT+CSTT\r";//Start Task and set apn
unsigned char s6[15]="AT+CIICR\r";//Bring up wireless connection with GPRS or CSD
unsigned char s7[15]="AT+CIFSR\r"; // Get Local Ip Address "is assign for GPRS Modem"
code unsigned char s8[50]="AT+CIPSTART=\"UDP\",\"219.64.118.125\",\"3500\"\r\n"; // Start Up TCP or Udp Connection
unsigned char s9[15]="AT+CIPSEND\r\n"; //Send Datat Through TCP or UDP Connection
unsigned char sd[46]="193308950\r\n"; // This is the Example Data Send through GPRS Modem
void call(unsigned char *z)
while(z[x]!='\0')
SBUF=z[x];
while(TI==0);
TI=0;
x++;
void send(unsigned char a)
SBUF=a;
while(TI==0);
TI=0;
void delay(unsigned int t)
unsigned int x1,y1;
for(x1=0;x1<t;x1++)
for(y1=0;y1<498;y1++);
void baud_rate_init()
TMOD=0x20;// Use Timer 1 8-bit Auto Reload mode
TH1=0xfd; //Baud Rate 9600
SCON=0X50;// 8 bit,1 stop bit
TR1=1; // Start Timer 1 for Serial communication
void main()
baud_rate_init();
while(1)
x=0;
call(s1);
send(0x0d);
delay(1000);
x=0;
call(s2);
send(0x0d);
delay(2000);
x=0;
call(s3);
send(0x0d);
delay(3000);
x=0;
call(s4);
send(0x0d);
delay(5000);
x=0;
call(s5);
send(0x0d);
delay(6000);
x=0;
call(s6);
send(0x0d);
delay(10000);
delay(10000);
x=0;
call(s7);
send(0x0d);
delay(10000);
delay(10000);
x=0;
call(s8);
send(0x0d);
x=0;
call(s9);
send(0x0d);
x=0;
call(sd);
send(0x1a);
delay(1000);
here is a sample code to connect to web server
Code:#include<string.h> #include<reg51.h> unsigned char x=0,i,g[20]; unsigned char s1[9]="AT\r\n"; //send "AT" command modem will response unsigned char s2[18]="AT+CIPMODE=0\r\n";//Select TCPIP Application mode unsigned char s3[30]="AT+CLPORT=\"UDP\",\"3500\"\r\n"; //set Local Port unsigned char s4[45]="AT+CIPCSGP=1,\"airtelgprs.com\"\r\n";//set csd or GPRS for Connection mode "ur GPRS provide address" unsigned char s5[15]="AT+CSTT\r";//Start Task and set apn unsigned char s6[15]="AT+CIICR\r";//Bring up wireless connection with GPRS or CSD unsigned char s7[15]="AT+CIFSR\r"; // Get Local Ip Address "is assign for GPRS Modem" code unsigned char s8[50]="AT+CIPSTART=\"UDP\",\"219.64.118.125\",\"3500\"\r\n"; // Start Up TCP or Udp Connection unsigned char s9[15]="AT+CIPSEND\r\n"; //Send Datat Through TCP or UDP Connection unsigned char sd[46]="193308950\r\n"; // This is the Example Data Send through GPRS Modem void call(unsigned char *z) { while(z[x]!='\0') { SBUF=z[x]; while(TI==0); TI=0; x++; } } void send(unsigned char a) { SBUF=a; while(TI==0); TI=0; } void delay(unsigned int t) { unsigned int x1,y1; for(x1=0;x1<t;x1++) for(y1=0;y1<498;y1++); } void baud_rate_init() { TMOD=0x20;// Use Timer 1 8-bit Auto Reload mode TH1=0xfd; //Baud Rate 9600 SCON=0X50;// 8 bit,1 stop bit TR1=1; // Start Timer 1 for Serial communication } void main() { baud_rate_init(); while(1) { x=0; call(s1); send(0x0d); delay(1000); x=0; call(s2); send(0x0d); delay(2000); x=0; call(s3); send(0x0d); delay(3000); x=0; call(s4); send(0x0d); delay(5000); x=0; call(s5); send(0x0d); delay(6000); x=0; call(s6); send(0x0d); delay(10000); delay(10000); x=0; call(s7); send(0x0d); delay(10000); delay(10000); x=0; call(s8); send(0x0d); x=0; call(s9); send(0x0d); x=0; call(sd); send(0x1a); delay(1000); } }
