[PIC] Send message using sim300 and picbasic - from a numberpicked from eeprom memory
alokdaga
Member level 2
I can send message normally using the following code
HSerout ["AT+CMGS=",34,"+91##########",34,13]
HSERIN 5000 , error, [WAIT(">")]
HSEROUT[ "Message" ,10,13]
HSEROUT[ 26]
HSERIN 3000 , Error,[WAIT("+CMG")]
LCDout "OK"
How can I send message to a number which is stored from location 0 to 9 in eeprom
I tried storing value in variable N1 TO N9 respectively
HSerout ["AT+CMGS=",34,#N1,#N2,#N3,#N4,#N5,#N6,#N7,#N8,#N9,34,13]
This causes the sim300 to hang...
You don't need to store the numbers in eeprom. Just store it in ROM memory and you can read it into RAM on startup before entering the super loop. It will be available all the time when PIC has power. Use a string variable or character array. in HSerialOut[] procedure call pass the variable (array) which holds the number.
Thanks for your suggestion... But my numbers are stored in eeprom only.... I can read them from eeprom into a variable and do... I tried sending the numbers one by one also in a loop but it does not work... sim 300 hangs... Pl suggest ... PICBASIC pro does not support string variable I think....
See the attached code. I tested it in Proteus and it works fine. I saw eeprom example code at PBP website and wrote this code. Try adding more numbers to eeprom.
  • SIM300 SMS SEND PBP.rar
thanks a lot. will try morning and let u know... :)
Try this code. Before Compiling change the four 10 digit mobile numbers in eeprom[] instruction.
Code - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
'*  Name    : gsmSim300.BAS                                      *
'*  Author  : Jayanth D                                         *
'*  Notice  : Copyright (c) 2014 Power Tech                     *
'*          : All Rights Reserved                               *
'*  Date    : 3/23/2014                                         *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
INCLUDE "modedefs.BAS"
DEFINE OSC 4
DEFINE HSER_TXSTA 24h
DEFINE HSER_RCSTA 90h
DEFINE HSER_BAUD 9615
DEFINE HSER_CLROERR 1
DEFINE HSER_SPBRG  25
mobileNo var byte[$B]
InnerIndex var byte
OuterIndex var byte
NumberStartIndex var byte
TRISC = %10000000
PORTC = $0
EEPROM ["9742453836123456789009876543210011223344"]
'EEPROM ["9742453836",0,"1234567890",0,"09876543210",0,"011223344",0]
start:
mainloop:
SendAT:
      HSEROUT ["AT",13,10]
      HSERIN 1000,SendAT,[WAIT("OK")]
      pause 2000
SendATCMGF:
      HSerout ["AT+CMGF=1",13,10]
      HSERIN 1000,SendATCMGF,[WAIT("OK")]
      pause 2000
      NumberStartIndex = 0
       for OuterIndex = 0 to 3
            for InnerIndex = NumberStartIndex to (NumberStartIndex + 9)
                    if (NumberStartIndex >= 0) and (NumberStartIndex <= 9) then
                        Read InnerIndex, mobileNo[InnerIndex]
                    elseif (NumberStartIndex >= 10) and (NumberStartIndex <= 19) then
                        Read InnerIndex, mobileNo[InnerIndex - $A]
                    elseif (NumberStartIndex >= 20) and (NumberStartIndex <= 29) then
                        Read InnerIndex, mobileNo[InnerIndex - $14]
                    elseif (NumberStartIndex >= 30) and (NumberStartIndex <= 39) then
                        Read InnerIndex, mobileNo[InnerIndex - $1E]
                    endif
                    pause 50
            next InnerIndex
            mobileNo[$A] = 0
            HSerout ["AT+CMGS=",$22,Str mobileNo,$22,13,10]
            HSERIN 10000,SendAT,[WAIT(">")]
            HSEROUT["SMS from SIM 300", $1A]
            HSERIN 10000,SendAT,[WAIT("OK")]
            LCDout "OK"
            pause 4000
            NumberStartIndex = NumberStartIndex + $A
       next OuterIndex
      GOTO mainloop
      END
tried... not working - loops out to sendAT
From where? After sending AT+CMGS="...?
It worked for me in Proteus. I have used PIC16F877A @ 4 MHz external clock. Change it to your MCU and clock.
Edit: Increase SerIn Timeout and delays and try.
It worked - .. thanks for your help.... I was using HSerout ["AT+CMGS=",34] instead of which I used HSerout ["AT+CMGS=",$22]
Thanks a lot
Decimal 34 and 0x22 are the same. It is ASCII char for double quotes. The versions with 34 and $22 both works for me.
But in mine it does not - 34 does not work and $22 works !! Even I am stumped...
Zip and post the code which doesn't work if 34 is used. I will test it.
