Send AT Command to Sony Ericsson W700i through USB cable
champnim
Junior Member level 2
sony ericsson at commands
I want to write a C code to send AT command to my Sony Ericsson W700i through its USB cable...can sumbody pls tell me how to do this
davemaster
Peru, South America
at commands for sony ericsson
Greetings
First:
1. What C compiler are you going to use?
2. What AT Command?
3. For example: AT+CBC (BATERY LEVEL)
Declaration
unsigned char atcbc[]="AT+CBC";
Use of AT Command
printf(atcbc);
putc(0x13); //CR Character, necessary for end the command transmission
4. Thats all you need. One more thing
5. Read the phone specific AT Command.
good luck
champnim
at commands sony ericsson
thanx fr ur help...can u tell me how to send this command to my phone connected thru its usb cable using the ouportb command...or is there another way of doin this?????????
davemaster
Peru, South America
sony ericsson usb commands
champnim said:
thanx fr ur help...can u tell me how to send this command to my phone connected thru its usb cable using the ouportb command...or is there another way of doing this?????????
1. First, Configure your hyperterminal to connect in COMX where is installed by the usb cable driver.
2. Once you have installed hyperterminal connection to that COMX, connect, then try with this basic AT Command:
> AT <enter>
> OK (the phone must respond with this)
3. If it doesn't respond to AT command, try to put the speed of your COMX port, to 9600, then 4800, and so on... that speed (Baud speed) depends on the Phone model.
4. When you receive the OK response... you will be ready to send other commands, for example:
>AT+CBC <ENTER>
>+CBC 0,23 (Response, where 23 means 23% of 100 of battery charge)
>OK
5. This is a must and never ignore step. Read, READ the AT manual of your phone.
Good Luck!
