This adapter is used to replace serial communication port. For example, you can use this adapter to connect singlechip and PC by serial communication. And you can change some serial device to wireless. For example, you can change AVR com jtag to bluetooth jtag. When pair this adapter and PC, pin code is “0000”.
characteristic:
1.Adopt CSR BlueCore2
2.Support bluetooth 1.1, width is 10 meters
3.Can use jumper to set baud rate,support:
(1).4800
(2).9600
(3).19200
(4).38400
(5).57600
(6).115200
4.Adopt slave mode
5.Adopt two supply power:5V or 3.3V。Powr connect manner:Through JP2 to supply 5V or 3.3V power; Through DB9 to supply power,9 pin connect to 5V or 8 pin connect to 3.3V。
