Self-bias is not used in class B power amplifier
Osawa_Odessa
Banned
Full Member level 3
Class-B push-pull amplifiers usually have single (non-differential) input and output, hence their quiescent input and output DC voltages usually are different - contrary to most differential amplifiers. So in most cases, their input bias voltage will be controlled (fixed) by a circuit network which is independent of the output quiescent voltage. I think this is meant by self-bias is not used.
Apart from this commonly used input bias scheme, self-biasing via feedback from the output to the input of course is possible: One just has to care for different DC and AC gain by an appropriate feedback network.
A class-B amplifier output is not biased so crossover distortion is produced (there is almost no output until the input to the output transistors reaches 2 x 0.7V in level) and sounds awful. Therefore almost all audio amplifiers have the output transistors in class-AB where they are biased a little and have very low distortion.
Thanks all!
I understand Audioguru but not quite understand erild's point.
If possible, please help me explain it more.
... not quite understand erild's point. If possible, please help me explain it more.
My explanation concerns the input biasing. I mentioned 2 possible input biasing schemes: independent from or dependent on the output quiescent (DC) voltage.
