FreshmanNewbie
Full Member level 6
My objective is to protect the pins of a device.
The pins are connected to an external connector which might be exposed to an ESD event.
Hence, I need to place an ESD protection device on that line.
So, my understanding is that, suppose, let me assume that the pin I am trying to protect is a USB signal from a USB hub which is going to a USB connector.
What I do is, search for a diode. The only parameter that I look for is the clamping voltage of the diode. Since the USB signal voltages during normal operation don't go beyond 4V, I select a diode that has a clamping voltage of 5V (max) @ 1A. And I make sure this clamping voltage of 5V doesn't exceed the absolute maximum ratings of the device's pin in the Hub, which is 5.5V.
Is my approach correct? If not please tell me what is wrong.
Also, please let me know if I have to consider additional paramters while selecting an ESD diode to protect the pin of a device in general.
Thanks.
Thanks.
