select the top or the bottom when add the parts
moustafaali
Member level 2
cairo,egypt
i ask how can i select that this part will be putten to the upper or the lower layer
can i select it in expedition
please advise with because i have documentation say just select the top layer
i need to know from which place in the tool
thanks
moustafa
touringmike
Member level 4
U.S.A.
The default should be the top.
When you select a part from the placement list, as you move it on the layout, there should be an "F" key to swap sides, like "F4" will be labeled push.
Pushing swaps between Top and Bottom
look at the bottom of the window where your info is. It should describe what each function key does for every specific application.
