relic180
Newbie level 3
- Joined
- Oct 12, 2009
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Fort Lauderdale
- Activity points
- 1,324
I apologize in advance, my knowledge of electronics and radio communication is extremely rudimentary and I have no formal education in either, but I'm seeking advice on a project I'm working on, and any input is greatly appreciated.
I'm trying to figure out a solution (or possibly build/have built) for communicating over a relatively small distance (between 100-150 meters) to some sort of very small receiving device, and then have that signal echoed back to the origin. The purpose would be to have the time between sending and receiving measured so that the distance between the two objects can be established. The echoing device will be mobile but the transmitting/receiving end can, and probably would be fixed.
I've read that different frequencies or wireless communication methods have different ranges as well as differing levels of reliability, strength, etc. Are their shorter range signals that would increase the reliability of the signal? Are their other ways to measure the distance between these two points besides a simple 'ping' method? Are their solutions that already exist for determining the direction of the received signal? To refresh the signal data multiple times per second, what what impact would this have on the frequency?
As for the 'echoing' object, what would be required to develop this sort of device? Can you build a small chip, that does not need a power source (or at least a small power source) to accomplish this? What elements are absolutely necessary on the 'echo' end that cannot be located on the transmitter/receiver end?
As for the transmitter itself, where would be a good place to find a pre-build piece of equipment that could be used for this? What's the cost associated with this sort of device? What would be the easiest way to relay this information to a computer?
This project is still at the beginning of the conception stage, so any input or ideas at all are extremely helpful. Oh, and are their any potential pitfalls that I should be aware of with something like this?
Thanks in advance.
Thanks in advance.
