iza_98
Newbie level 2
Hi, i just joined this group and really hope you guys can share info with me..currently i'm working on a proj that need me to use ethernet and data logger. basically i need to use PIC18 series..however, i found it is quite difficult since i need to cater data logger issue which i need to send and save some data from sensors, that later need to be sent to an application via ethernet. Currently i'm using PIC18f4620..
in short the development should include the following:
1) Ethernet connection
2) RS 485
3) EEPROM to save data
4) RTC
5) sensor interface
can anyone suggest better solution/IC?
thanks in advance..
2) RS 485
4) RTC
5) sensor interface
thanks in advance..
