SDR SDRAM controller code needed (Verilog/VHDL)
vlsi_whiz
Full Member level 4
Penang
sdram controller verilog
Does any one have the SDR SDRAM controller code with a generic local side interface (Addr, Data, WR#, CS#,etc). I've tried the opencores, but it does not suit my design. Even looked at altera's version, but its customized for a certain processor (has the commands coming from local side to controller).
Even if you have the specs and state machines for the SDR SDRAM controller, that would do.
vlsi_whiz
Full Member level 4
Penang
sdram vhdl
Thanks, but the controller does not have the local side data IO. I need the data IO to switch the SDRAM between the two DSPs.
I may need to modify your code. Thankz anyways.
sanjay11
Member level 1
sdram model hdl
search on opencores.org
