[SOLVED] SDF file backannotation problem: "Instance X does not have a generic named Y"
noureddine-as
Junior Member level 2
After synthesizing a SystemVerilog IP in Design Compiler 2019, I exported the SDF timing backannotation file to be used in VSIM for post-synthesis simulation.
However, VSIM outputs a lots of errors like this
# ** Error (suppressible): (vsim-SDF-3240) ......./SDF_FILE.sdf(64557): Instance '/tb/ip_instance/ip_top/U25942' does not have a generic named 'tpd_a_q_posedge'.
# ** Error (suppressible): (vsim-SDF-3240) ......./SDF_FILE.sdf(64557): Instance '/tb/ip_instance/ip_top/U25942' does not have a generic named 'tpd_a_q_negedge'.
# ** Error (suppressible): (vsim-SDF-3240) ......./SDF_FILE.sdf(64557): Instance '/tb/ip_instance/ip_top/U25942' does not have a generic named 'tpd_b_q_posedge'.
# ** Error (suppressible): (vsim-SDF-3240) ......./SDF_FILE.sdf(64557): Instance '/tb/ip_instance/ip_top//U25942' does not have a generic named 'tpd_b_q_negedge'.
Knowing that in the generated Gate netlist I get the following
  XNR21 U25942 ( .A(n20301), .B(n20300), .Q(n20320) );
Now, when I check the generic parameters of the Entity "XNR21" in the VITAL library I found the following definition.
Which confirms that, indeed the entity doesn't have those "*_posedge" and "*_negedge" generics. Any ideas how to resolve this problem ?
-- entity declaration --
entity XNR21 is
   generic(
      TimingChecksOn: Boolean := True;
      InstancePath: STRING := "*";
      Xon: Boolean := True;
      MsgOn: Boolean := True;
      tpd_A_Q                        :	VitalDelayType01 := (1 ps, 1 ps);
      tpd_B_Q                        :	VitalDelayType01 := (1 ps, 1 ps);
      tipd_A                         :	VitalDelayType01 := (0 ps, 0 ps);
      tipd_B                         :	VitalDelayType01 := (0 ps, 0 ps));
   port(
      A                              :	in    STD_ULOGIC;
      B                              :	in    STD_ULOGIC;
      Q                              :	out   STD_ULOGIC);
attribute VITAL_LEVEL0 of XNR21 : entity is TRUE;
end XNR21;
Re: SDF file backannotation problem: "Instance X does not have a generic named Y"
Using Verilog behavioural libraries (instead of VITAL VHDL stuff) along with Verilog output Netlist resolves the problem.
