shvi
Junior Member level 3
hi,
i am using below code for SD CARD read and write using lpc2148 blueboard.
when i send data to SSPDR then data is sent into buffer but it will load into SSPDR.
and for receiving no data will come from SSPDR to buffer.
for receiving how i load data into SSPDR so it will come into buffer.
below is my code:
i don't know why data is not come into SSPDR?
help me thanks,
below is my code:
int main (void)
unsigned char *arr1 = "ABCDEFGH";
unsigned char *arr2;
init_lcd();
spi1_init();
while (1)
void init_lcd( void )
set_lcd_port_output();
delay(100*100);
lcd_command_write(0x28); /* 4-bit interface, two line, 5X7 dots. */
lcd_clear() ; /* LCD clear */
lcd_command_write(0x02); /* cursor home */
lcd_command_write(0x06); /* cursor move direction */
lcd_command_write(0x0C) ; /* display on */
lcd_gotoxy(0, 0);
lcd_clear();
U32 spi1_init(void)
U8 i, Dummy;
/* Configure PIN connect block */
/* bit 32, 54, 76 are 0x10, bit 98 are 0x00 */
/* port 0 bits 17, 18, 19, 20 are SSP port SCK1, MISO1, MOSI1, and SSEL1 */
/* set SSEL to GPIO pin that you will have the totoal freedom to set/reset
the SPI chip-select pin */
PINSEL1 = (PINSEL1 & ~(3 << 6)) | (1 << 7);
PINSEL1 = (PINSEL1 & ~(3 << 4)) | (1 << 5);
PINSEL1 = (PINSEL1 & ~(3 << 2)) | (1 << 3);
SSPCR0 = SSP_CONFIGURATION0;
SSPCR1 |= SSPCR1_SSE;
/* SSPCPSR clock prescale register, master mode, minimum divisor is 0x02 */
SSPCPSR = 0x2;
for ( i = 0; i < FIFOSIZE; i++ )
Dummy = SSPDR; /* clear the RxFIFO */
return( TRUE );
** Function name: spi1_send
** Descriptions: Send a block of data to the SPI1(SSP) port, the
** first parameter is the buffer pointer, the 2nd
** parameter is the block length.
** parameters: buffer pointer, and the block length
** Returned value: None
void spi1_send(U8 *buf, U32 Length)
U32 i, Dummy;
unsigned char c,arr[8];
for ( i = 0; i < Length; i++ )
/* as long as TNF bit is set (TxFIFO is not full), I can always transmit */
while ( !(SSPSR & SSPSR_TNF) );
SSPDR = *buf;
//arr[i] = *buf;
buf++;
while (!(SSPSR & SSPSR_RNE));
*buf = SSPDR;
return;
** Function name: spi1_receive
** Descriptions: the module will receive a block of data from
** the SPI1(SSP), the 2nd parameter is the block
** length.
** parameters: buffer pointer, and block length
void spi1_receive(U8 *buf, U32 Length)
U32 i;
/* As long as Receive FIFO is not empty, I can always receive. */
/* since it's a loopback test, clock is shared for both TX and RX,
no need to write dummy U8 to get clock to get the data */
/* if it's a peer-to-peer communication, SSPDR needs to be written
before a read can take place. */
while (!(SSPSR & SSPSR_TNF));
SSPDR = 0xAA;
*buf = SSPDR;
buf++;
return;
help me thanks,
