Schottky diode selection
kamal20khz
Junior Member level 2
Chennai, India.
Hi everyone. I need help in selecting Schottky diode for a rectifier at 2.4ghz. I have few 1n5819 diodes. Will they work at this frequency?
goldsmith
Advanced Member level 5
Tehran - IRAN
Hello Dear kamal20KHZ ( why 20 KHZ ?!!)
For schottky diode selection , you should , pay attention to below things:
1-Trr ( recovery reverse time )
2- maximum current
3- breakdown voltage
and internal capacitance
Best Wishes
Goldsmith
jpanhalt
Advanced Member level 3
I found one instance where a hobbyist asked about using the 1N5819 for 2.4 GHz detection, but there was no follow-up:
2.4Ghz field strength meter? - Page 2 - RC Groups
Some other options are listed there, though. Here are two other sites with frequency data. The first lists a couple of options that may be available i your area, such as the 1N5711 on page 2 and the BAT62 on page 7.The second one is also making a 2.4 GHz detector and gives other sources.
https://www.rfmicrowave.it/catalogo/eng/A.pdf
Field Strength Meter for 2.4 Ghz Wireless LAN
Have you searched on 2.4 GHz field-strength meters to find what others are using that might be available in your area?
John
FvM
Super Moderator
Staff member
Bochum, Germany
Do they look like microwave components? You won't have much fun with 1N5819 above 1 MHz or so.
kamal20khz
Chennai, India.
Is 2.4ghz only mean microwave? I'm designing the ckt for RF. Name any diode if u know for this purpose. What abt bat15 or bat62?
FvM
Super Moderator
Staff member
Bochum, Germany
Both are well suited for GHz range, but have different parameters. You didn't yet mention a frequency of your application. See the more detailed comments from jpanhalt.
taylane
There was a book by Steve Maas, I cannot remember the full name, but it was something like: "Microwave Cookbook".
This book includes extensive information about the utilization of diodes in various areas of Microwave Design. You can find detailed info on diode selection for your application.
kamal20khz
Chennai, India.
I have some options such as bat15 in rsdelivers. But my problem is that they are of surface mount SMD type. As i'm designing the ckt in general pcb i think i couldnt solder those. I need something like axial leaded ceramic or glass case diode.
jiripolivka
Santa Barbara
I used and can recommend Siemens BAR12 Schottky diode. I also used HSMS-series from Agilent, also good detectors at 2.45 GHz.
