In the following website you will find Schmitt triggers build around transistors, gates and opams ..
Choose whichever you like or need .. **broken link removed**
hi
for designing a schmitt trigger circuit for desired levels......., first change the magnitude of sign wave with adding some dc components to that......then u can get 5V and 0V ....... but first u check it in software circuit design then go for the original one..........:|
