schematics of PHILIPS brilliance LCD 200p4 required
ferdipace
Newbie level 3
Newbie level 3
philips brilliance lcd 200p4
Hi all
My monitor PHILIPS brilliance LCD 200P4 does not switch on anymore (even LED is off) .
Anyone has schematics and/or tipps for debug ?
thanks in advance for the help
ferdinando
philips brilliance 200p manual
ferdipace said:
Hi all
ferdinando
hi
most likely your problem is in the power supply section and most of the time it's a bad electrolytic capacitors .
unfortunately i don't have the manual for that 200P4 , i have some 220 series complete service manual including the power section but don't know if they could work for your model or not :(
good luck
Regards
lcd schematics
can you upload 220 series complete service manual including the power section , I y=think it would help a lot .
thanks
regards
philips brilliance 220
@ ferdipace.
pls. post here chassis no. and pic. of power supply and other pcb.
wbr
schematic power board lcd
thanks
regards
hi
here you are :)
good luck
Regards
philips 200 p4 manual
@ baraka42
chassis is 200P4MG/00, if you have the service manual please attach :)
this evening I will post a picture of power board
thanks for the help
@ sawwa7 :
thanks for the help but I was too optimistic : the power board of 200P looks too much different, thanks anyway
ferdi
philips brilliance manuel
Hi
I attach a picture of power board .
yesterday I removed the power board from monitor and when i tried to connect it standalone to power 1 of the fuse (bootom right corner of picture) was blowing up .
Any idea what I need to check first ?
thanks for the help
