Schematic Simulation with Verilog XL
tia_design
I designed a traditional JK flip flop, the entry is schematic, and simulation is done by Verilog XL. I found that the output of such JK flop flop is undefined. I found the reason is that in this JK, the output is connected back to the input nmos, which is undefined when simulation is begun. Who can tell me how to avoid this? Thanks
eda_wiz
Advanced Member level 2
Apply Reset while Intialising the Simulation
spauls
Apply reset and check for all Input combinations.
marksile
Member level 1
You can reset or set. you can add default to q and qn in testbench file also.
hover
Junior Member level 2
China
I have met same question when I first use the tool.
You must add a reset or set signal to the flip-flop in order to initialize it.
