TCAD-Simulation and Modeling
Quick Overview
Category
Uncategorized
Language
Total members
61
Total events
Total discussions
24
Total views
12K
Total albums
SCHEMATIC FOR MINI WIND TURBINE
sriorg
Newbie
need to simulate a grid tie inverter for a mini wind turbine. The grid is 120V and i have to synchronize the voltage from the mini wind turbine generator and the voltage from the grid. They must be synchronized to 60Hz. Would you please tell me how to make a schematic of a grid tie inverter on LtSpice?
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
LTSpice is a popular (free) simulator. Do you have prior experience making circuits with LTSpice?
Do you have prior experience making (simulating) a power inverter?
The aim is to sense grid voltage going positive, so you switch your source to send a half-cycle sinewave at positive polarity, and sufficient amplitude to overcome grid voltage, lasting 1/120 sec.
Then do similarly for negative polarity.
dick_freebird
Advanced Member level 5
USA
You could use the windmill to drive a regular
induction motor above its synchronous speed
and get the line sync for free. Maybe need some
sort of contactor to enable the line connection
only when RPMs are sufficient to source to,
rather than sink power from the grid. If that is
a levied requirement in the homework.
If you want to do it with semiconductors that's
going to be a busy circuit with a lot of stuff you're
obviously unprepared to deal with.
sriorg
Newbie
I dont have the experience making a power inverter.
Actually, I need the circuit diagram for the said query with LTSpice software.
KlausST
Super Moderator
Staff member
You need a more clear description on what the goal of the simulation is.
If you are interested in calculationg efficiency, or regulation stability of the inverter (for example) you may need the true schematic. I doubt any manufacturer will give you a fully detailed schematic that can be used for circuit simulation.
Without a lot of experience (and knowing the inverter details), I doubt a self made simulation will give useful results.
But I can imagine a lot of tasks where no schematic is needed.
A simple efficiency simulation may be done in excel. Maybe for this you just need to know the
Input_power to output_power relation of the inverter.
It all depends on the task and it's goal.
There is a goid chance that you spend a lot of time for inverter circuit simulation, while you miss the overall goal.
Klaus
LaTeX Commands Quick-Menu:
