jayTudu
Hi frnds,
This post is regarding the difference between the scan reordering and scan stitching. I came across the book "The VLSI test principle..." by Xioqing Wen et al. where they have defined the Scan stitching methodology as the final connection between the scan cells, the out put of one scan cell is connected with the input of another scan cell. This is fine. But, I got little confused with the term scan reordering. The scan reordering as they have defined is the reordering of the scan cells based on the physical location of cells, meaning, the placement of scan cells will be changed. However, I have understood that the scan reordering is just to mean the reconnection of scan cells based on the reordering criteria. No need to chage the placement of cells. Although its just a matter of terminology some time its confusing also.
If any one you are working in this area please give your thought. You can refer the book by Xioqing Wen and papers by Patrick Girard on scan reordering.
Joyfully,
Jaynarayan.
Joyfully,
Jaynarayan.
