Scan Insertion Test Protocol
sampham04
Junior Member level 2
I am trying to insert a scan chain into the s27 circuit using Synopsys DC and I am having trouble writing the test protocol. When I create the test protocol I am using the command:
create_test_protocol -capture_procedure single_clock
to specify that I do not want multiple clocks, but when I try to write the test protocol in a .spf file using the command:
write_test_protocol -out s27_dut.spf
I get the following warning:
Warning: The multi-clock protocol requires that the strobe time be before a clock's pulse if it is used for transition fault testing. (TESTXG-56)
I don't understand why I am getting this warning since I specified the there should only be one clock.
Can anyone help me fix this problem, please?
Thank you!
