shahal said:Dr Dft, let me ask a question. Lock up latches, ofcourse you use it to cross clock domain boundry. Would you use lock up Latches between adjacent flops if the clock was skew between the two flop clocks was greater than the data propagation path between the flops?
My understanding is yes you would, given the above criteria because the second flop will latch the new value of the first flop. Is my understanding correct or is this some how tool dependent and some tools will insert LLs and some wont?
If the skew is small, then you should leave it to the backend tool to fix the hold time violation (by adding buffer delays).
If the skew is large, most probably it is because it probably they are from different clock trees. In this case, you should try to separate the clock tree sources during scan insertion, and treat them as different clock domains.
