Scan chain insertion with RC
anssprasad
Member level 5
I got the following report when I used report dft_setup command in RC after scan chain insertion.
test_mode:
object name: h_resetn
pin name: h_resetn
hookup_pin: h_resetn
hookup_polarity: non_inverted
active: high
ideal: false
user defined: false
My h_resetn signal is active low. I did not explicitly specify the reset control signal to the tool. In the above report it shows that the reset is active high. I am confused.
_________________
Thanks
Prasad
During test, presumably you don't want the reset to be asserted.
I.e. is it saying the active state of test_mode rather than reset?
    anssprasad
Hi Prasad,
I think default is -active high, If scan chain is stitched then it is fine. You can check the ATPG by constraining the reset as active LOW signal.
Thanks
C Santhosh Kumar
    anssprasad
